2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Juice Box aka JB3 stage 1 for N55...initial impressions
      06-13-2011, 06:49 PM   #23
blackberrycubed
Drives: 535i Xdrive
Originally Posted by CitrusgutsIS View Post
just installed it and not too impressed my 335 is oulled so much harder stock IMO
Did you adjust the boost? Don't you have to let the car adjust to the new tune by driving it for a bit?
Are you basing your dissatisfaction with tune solely on butt dyno feel?
      06-13-2011, 06:53 PM   #24
jaekeem
BMW Noobie
jaekeem's Avatar
Drives: e90 M3 e46 M3 Macan S Model S
Originally Posted by blackberrycubed View Post
Jakeem: Is this with the default boost settings which is like +2.75? or did you bump it up? I am reading that +4.0 boost gives the best power for an otherwise stock car.
Here is the link posted by dieselweasel on downloading the software to make the changes. I havent done this myself, but I'd address caution when making these changes to the car.
http://www.n54tech.com/forums/showthread.php?t=7992
2011 F10 535i | Build Thread | Power Mods & Dynos
      06-13-2011, 07:50 PM   #25
DieselWeasel
Drives: '11 335d|'11 535i|'13 X3 3.5
Jakeem: Is this with the default boost settings which is like 2.75? or did you bump it up? I am reading that 4.0 boost gives the best power for an otherwise stock car.
I have tried stock settings, 3.75, 4.0, 4.5, 4.75, and 5.0. No check engine lights anywhere but the car feels fastest at 4.0. I'd like to dyno mine at a couple of different settings and see what the actual numbers show. I'm quite sure that it is quicker at the higher boost settings at higher RPM but there is noticeably more lag the higher I went over stock boost.
      06-13-2011, 08:46 PM   #26
lgk
Drives: 2013 M3
I would tend to agree that 5 psi may not feel as strong because of the increased lag as you go up on the power band. I am installing aftermarket exhaust tomorrow and already have a K&N so we shall see if the free flowing exhaust helps with the boost.
It has been really hot here and any forced induction vehicle suffers after about 85 degrees in my humble experience.
      06-13-2011, 10:15 PM   #27
blackberrycubed
Drives: 535i Xdrive
How was the lag @ 4.00 psi? was it very noticeable ? would you go as far as saying it was annoying?
      06-13-2011, 10:30 PM   #28
DieselWeasel
No, just a touch more than stock. Not bothersome in the least. You'll forget all about it after about 5 minutes.
      06-14-2011, 02:23 AM   #29
jaekeem
BMW Noobie
jaekeem's Avatar
Diesel I think I asked you this before but what octane gas are you running? I'm going in to get some more dyno pulls done at higher boost and higher octane gas this week.
LGK - What exhaust system are you getting? Its been so hard trying to source any exhaust system. Even the custom muffler shops worth looking at in socal are booked over 2 weeks out!
I cant wait to see how this all works and what the dyno numbers look like at all the different boost settings.
By the way Diesel do you know what the maximum or limit of the JB Stage 1 boost is set at?
      06-14-2011, 03:41 PM   #30
MileHiGolfer
Drives: 18 m550i
Keep it up boys - I'm enjoying the reading as you play with these. Looking forward to more dyno results...
      06-14-2011, 05:47 PM   #31
CitrusgutsIS
waste of space
Abu Dhabi
9
Drives: 2012 750 M-sport
havent adjusted boost yet, still dont know what connector or laptop is compatible to get this done
2011 535 M-sport l xdrive l adaptive drive l BSM l Dakota
2011 335 is l DCT l BSM l saddle brown l Everything else l Sold
2011 x5 35 l AW l red interior l everything else l
      06-14-2011, 06:41 PM   #32
jaekeem
BMW Noobie
jaekeem's Avatar
I believe you can go to any computer store to get the serial to USB cable. Average costs are from my findings around $30USD.
As for laptop compatibility any windows based PC or mac with windows on it can run the application provided by Terry at Burger.
      06-14-2011, 09:03 PM   #33
lgk
Drives: 2013 M3
Terry's cable is truly proprietary. It will not work with a standard serial to USA. I had a Magnaflow system installed-much lighter, direct bolt on with no cutting.
When I first drove it, it was strange-it actually felt less powerful. I was concerned that the low RPM torque power delivery was effected by the lower back pressure.
I reset the ecu and drove for 20 miles and it felt better. I then raised the boost to 4 PSI. Seat pants it is truly hard to know whether their is much difference in power, especially when dealing with the extra noise. I don't necessarily consider the sound appealing but that is subjective.
      06-14-2011, 11:58 PM   #34
blackberrycubed
Drives: 535i Xdrive
How do you reset the ECU?
So even after setting it to 4psi you can't tell the difference compared to stock ?
      06-15-2011, 07:40 AM   #35
DieselWeasel
I'm running 93 octane here in Atlanta.
Not sure of the limits of the JB Stage 1. I have run 6 PSI over stock on 93 octane gas with no CEL or other driveability problems but car seems happiest at 4.0. At the moment it is HOT HOT HOT here in Atlanta, somewhere around 75 degrees in the morning and 95-98 afternoon and humid as hell so the butt dyno seems a little off and I know the power isn't nearly as high as it could be with cooler weather.
      06-15-2011, 07:25 PM   #36
AKSteve
Drives: G82 M4 Competition Convertible
For anyone here who did the install themself, was your MAP sensor plug a pain in the butt to get to? Mine was tucked underneath the back of my airbox, facing towards the front of the car. It wasn't "under a plastic cover" like the install instructions stated. I had to prop the airbox up as much as I could and slide a butter knife under it to undo the stock plug-in. Getting the JB3 replacement plug back into it was a bit of a pain as well. Having small hands would probably help. For a while there, I was pretty sure I was going to have to take the airbox off entirely.
I haven't driven the car as of yet. All I did was start it up to make sure I didn't get a CEL.
      06-16-2011, 02:13 AM   #37
jaekeem
BMW Noobie
jaekeem's Avatar
I really cant wait to turn up the boost soon, I think it'll be so much fun.
AK Steve,
I saw the install for the JB and they had a hard time reaching it too on our cars.
As for the car you will need a few complete pulls for the car to adapt. It took 4-5 dyno runs and 4-5 full throttle passes for the car to adjust to the tune. The more you drive it the more the car adapts to it.
I hopped on the dyno again today at EAS and saw the powerband from the installation day until now and it looks smoother from an already smooth power curve.
All I can say is I'm a believer of the JB you can look at the other tunes out there but I really doubt you can find a smoother install or even smoother powerband. Price definitely does not dictate quality in terms of these piggyback units.
Getting antsy waiting to increase boost on this car
      06-16-2011, 03:40 AM   #38
AKSteve
OK, so it wasn't just me who found the install a pain. I always read these posts that say things like, "It only took me 15 minutes to install, and I'm a complete moron!"
I had to prop my airbox up by wedging an empty plastic bottle underneath, unclip 3 sets of cables from the airbox to move them out of the way, lay a blanket on the engine and completely get on top of it so I could reach the MAP sensor under the airbox. After disconnecting the stock cable, attaching the JB3 cable in its place was a process of blind fiddling and dumb luck.
Now that it's stopped raining here, I'm about to go a midnight drive to check things out. I'm curious, with a chip installed, does Sport & Sport + still have an effect on how the car responds?
Thanks,
Steve
      06-16-2011, 08:51 AM   #39
Snowrider
Drives: 2011 535i Xdrive Msport
I received my jb3 for the n55 on Monday. Haven't had a chance to venture into the installation process but have surveyed the engine bay, which is totally different from the instructions posted on the install guide. I will admit I am a tuning newbie, but nothing seems the same, don't know if I should just bring it to a shop to get installed the first time around.
I noticed the odd placement of one of the sensors facing my windshield. Good thing is I found all of them, from there i feel it's going to be a bit of any experience.
If anyone here is experienced in installation, would love to hear a DIY on this install. Thx
Steve
      06-16-2011, 11:16 AM   #40
blackberrycubed
Drives: 535i Xdrive
it would be nice if someone could post a small video showing the install on a F10.
Any takers?
      06-16-2011, 11:40 AM   #41
AKSteve
It's actually pretty easy to install, except for the MAP sensor. Your option with that one is to either remove the airbox or spend a frustrating period of time trying to get at it with the airbox in place. I wasn't interested in taking my airbox out just for this install, so I went ahead and installed it with the airbox in the way.
First I pulled the airbox up as high as I could by hand, then stuffed a tall, empty plastic water bottle in to hold it up. Then I lifted up the tubes of cables that are strapped to the side of the airbox and moved them out of the way. With the cables out of the way, it's not that hard to slide a thin butter knife or something in there from the side to unclip the original cable from the sensor.
At this point, no matter how frustrating it is, you will motivate yourself to get the JB3 cable in place because your car is now undriveable until you do. I put a blanket across the top of my engine and laid on top of it so I could get into a good position to slide my hand in there and wrestle with getting everything in place. If you have a set of long needle-nose pliers or something like that, it might be easier. Or, if you have small hands, it might not be hard to do it by hand.
In any case, now that i have it installed, I don't plan on messing with it until my next visit to the dealer in 6,000 miles or so. This isn't something you want to do very often. The top photo is a view of the MAP sensor partially tucked underneath the back of the airbox. The second photo is a view from the side after propping up the airbox and moving the attached cables out of the way.
      06-16-2011, 01:08 PM   #42
blackberrycubed
Drives: 535i Xdrive
^^^ Thanks so much !!!
Edit: What build date is your car?
      06-16-2011, 01:15 PM   #43
Snowrider
October 2010 on my F10.
      06-16-2011, 02:32 PM   #44
jaekeem
BMW Noobie
jaekeem's Avatar
Thanks,
Steve
Steve you should have all the settings still with sport and sport+. Its when you start messing with the suspension by changing out the stock shocks for the dynamic damper control that eliminates the use of those features.
The JB should allow you to use those settings still...I'd like to hear your feedback with the JB and in sport+ mode.
The person who installed my kit did pretty much the same thing to get to that harness. He did not remove the airbox but pulled it loose and then wiggled around to get to that one.
My car has a December 2010 build date fyi
