Watch the 2012 528i Turbo 4 (N20) Take on Its Older 6 Cylinder on the Road and Dyno
Thread Tools |
| 05-07-2012, 01:42 PM | #89 | |
![]() 110
Rep 2,323
| 05-07-2012, 02:10 PM | #90 | |
TIM YOYO
1548
Rep 3,295
Drives: 2013 M3
So if I feel that the 528i lacks power for my wants, I need to get schooled on driving? The implication is that my driving skill is in need of education/correction. If someone feels that the N20 lacks sufficient power for their tastes, then that's their opinion. I'm not offended either way, but I am put off when someone treats their own opinion as some sort of empirical truth. No one is saying we "need" more power than the N20. We're saying we want it. That's all.
Current: 2026 X3 M50 - B58 Arctic Race Blue / Amber / Atlas Grey /
Past:: 2013 X3 xDrive28i - N20 Mineral Silver / Sand Beige / Premium, Tech Past: 2013 ///M3 - Interlagos Blue Black M-DCT Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport |
| 05-07-2012, 02:25 PM | #91 |
Rep 4,171
Xenons I actually "need". After driving for years with my Xenons in my e46, the only things better are the adaptive Xenons in the F10. I would never own a car without them
| 05-07-2012, 02:38 PM | #92 | |
Rep 4,171
| 05-07-2012, 03:03 PM | #93 | |
![]() 110
Rep 2,323
| 05-07-2012, 03:04 PM | #94 |
Rep 4,171
| 05-08-2012, 02:02 AM | #95 | ||
![]() ![]() 9
Rep 343
![]() The thing is, X men is trying to tell us that you need the power if you living in the states and for other place you don't. He (assuming a guy) is trying to convince everyone to think that way, wouldn't you think that's what you are referring to "someone treats their own opinion as some sort of empirical truth"It was all wants, doesn't have anything to do with needs. He admits that already, there's nothing wrong with having wants. Quote:
2011 F10 - Sophisto Grey / Cinnamon Brown
You can find me in E60.net too! Gone (but not forgotten) 2005 E60 523i, 1999 E39 523i, 1998 E46 323i ![]() |
| 05-08-2012, 08:07 AM | #96 |
Rep 4,171
![]() ![]() Happy to have a beer anytime with anyone. Cheers! |
| 05-12-2012, 04:33 PM | #97 |
Rep 5,111
I call BS on the horsepower at the crank figures posted in the video...
First take a closer look at the video at 0:56 and then at 1:00. You will notice in the upper right hand corner on the dynochart that for the 4 cylinder it clearly says max 192hp and then for the 6 cylinder it says max 181,2hp. That is a difference of 10,8hp at the wheels. The 4 cylinder is supposed to be 240hp at the crank and the 6 cylinder 208,4hp. The difference between wheel hp and crank hp on a dyno like this has to be down to drivetrain losses (or down to different parameters put into the dyno for calibration - altering air temperature on "before and after" runs is one known factor that tuners sometime use to "boost" the hp ratings). So are we to believe that the 4cyl has drivetrain losses of 48hp and the older 6cyl car only looses 27,2hp through the drivetrain??? Wheel hp is the only reliable number on a dyno like this. Crank hp, when calculated from rwhp from a dyno, has to many variables and possibilities for tampering with to be used for reliable comparison. Sometime you might see a tuner claim, let's say a 50hp gain at the crank. But if you compare the dyno sheets you might see that there is only a 20hp difference on rwhp. Just by changing a few parametres on the dyno (like air temp, air pressure etc), the software will adjust it's calculations and the crank hp will be higher (because an engine will have less power in hot conditions and/or high altitude the dyno will calculate crank hp as it will be at sea level and 20deg C - if the dyno operator tells the dyno that it's hot and that we are at a high altitude the dyno will adjust its crank hp calculations). The 4cyl is still faster but there is probably only around 10hp difference between the two engines in this test. |
| 06-07-2012, 01:45 PM | #98 | |
Rep 1
| 06-07-2012, 11:32 PM | #99 |
Rep 7
I am currently driving a F10, Jun 2010, 528I (sport gearbox). I took it for maintenance and got a 520I 2012 (sport gearbox) model as courtesy car.
The 4 cylinders 520I is very disappointed and sounds like a diesel taxi cab when it is idle. Initial acceleration is fine but not in a mid-range i.e. 60 to 120km/h... engine is lazy and even rev to 5000rpm... No way to compare with my current 528I which delivers relentless acceleration. Not sure about the 4 cylinders 528I sounds like. |
| 06-08-2012, 12:57 AM | #100 |
![]() 63
Rep 1,544
N20 528i is much faster than N20 520i, esp mid & top end. Even in comfort mode with the soft throttle mapping, u can easily spin the wheels on dry roads.
520i only have 184ps & 270Nm, not fair to compare with ur 528i which has 258ps & 310Nm. |
| 06-08-2012, 07:48 AM | #102 |
Rep 4,171
| 06-08-2012, 08:54 AM | #103 |
![]() 110
Rep 2,323
I drove both the 2012 528i and 535i as well and noticed a big difference. In my opinion, the N20 engine fits the new 3 series much better than the 5 series. On a marketing point of view, I think it is smart for BMW to offer a small engine for the 5 series. There is a growing market in the US for cars with an economical engine, it also helps BMW to comply with the upcoming CAFE requirements.
| 02-17-2013, 03:08 PM | #104 |
Rep 5,111
To add some info to the short acceleration video that was at the start of this thread.
Check out these three acceleration videos on Youtube: 528i (N20) 528i (N53 European 3l 6cyl) 258hp 535i The 528i (N53) and 535i both take around 24,5sec from 0-200km/h. The 528i N20 (4-cyl) takes around 32,8sec from 0-200km/h. Around 8sec more than the 6cyl 528i, even though it's just as quick to 100km/h... As you can see the N20 528i starts to struggle (compared to the 6-cyl cars) at higher speeds and looses at lot of time from around 150km/h and upwards. |
| 02-18-2013, 08:48 PM | #105 |
Rep 900
Drives: 2021 X5
Nice comparison. I am not surprised.
I had a rental in Vegas a couple of weeks ago. It was a 528 F10 with the turbo. I was skeptical at first as I am used to my 535 with JB4 stage 2. After about 400 miles of driving I have to say I was impressed and the bias against it was gone. It being a rental, it didn't have the m sport package and comfort seats so the comfort level wasn't the same (non msport steering wheel feels way too thin) but overall I was very impressed.
2018 540d xDrive Carbon Black Metallic on Cognac leather. Spec'd out to the max
2017 Mercedes C43 AMG Coupe. Black on black |
| 02-19-2013, 01:31 AM | #106 |
Rep 331
Drives: BMW 520D Touring 2012
I just drove the 328i, what a rocket. Wheels spinning up to 50 kmh without problems.
In sweden the price difference between 528 and 535 is 11000$ which is a bit much for 0.6s faster to 100kmh. The there is the sound and refinement difference to consider. But coming from diesel the 528 i really great in that way anyway. |
| 02-19-2013, 06:00 PM | #107 |
Rep 473
Drives: 2013 X5 3.5 Premium
Garage List 2017 Nissan Titan SV [10.00]
2018 Mercedes E400 ... [10.00] 2013 X5 Premium 3.5 [10.00] 2008 Porsche Cayman S [10.00] 2020 Chevrolet Subu ... [10.00] |
I just dropped off my 528i rental in Vegas. Can you believe in 3 days I managed to put over 300 miles. Every day between meetings we'd just head to the car and go for a drive -- Lake Mead, Hiway 215 and even 15 towards Los Angeles.
The start/stop is quite annoying. I think I could get used to the feature, but the slight shudder when the engine restarts is offputting. I test drove a Porsche Cayenne last year with this feature and I literally could not feel the re-start happening at all. On the other hand, the ride managed to be controlled and yet silky reminding me more of my former E-class. And the mileage was remarkable -- after all that driving it only took 5.4 gallons. The 4 cyl seemed to have all the power and more that I needed and other than knowing that upfront it definitely didn't feel like it. |
| 02-19-2013, 08:26 PM | #108 | |
Rep 900
Drives: 2021 X5
| 03-08-2013, 11:57 AM | #109 |
Rep 385
Drives: BMW X3 28i
2 different sales guys at my local BMW dealership have said negative things about the 528. They feel the 4 cylinder engine isn't powerful enough for such a heavy car. I have the 4 cylinder X3 and feel it's plenty powerful, though it's a lighter vehicle and they both said there's a difference. I asked about them knowing of any clients that have buyers remorse and they both said no.
What do you owners of the 2012 or 2013 528's feel about your car? Are you happy with it? Do you feel that it has adequate pick up? Any buyer's remorse? Looking at purchasing a 5 Series later this year. Would love to save the $5K and have better fuel economy. Thanks in advance for your comments!
2014 BMW 528ix M Sport- Space Gray Metallic, Mocha Nappa Leather, Anthracite Wood Trim. Packages: ACC, DA, DA+, Lighting, Luxury, Prem, H-K SS, SAT, Rear Shade
2013 BMW X3 28i M Sport - Deep Sea Blue Metallic, Sand Beige Nevada Leather, FS Wood Trim, HG Roof Rails, and BMW Apps. Pirelli P7 RFTs. Packages: Cold, Con, DHP, Prem, Premium Sound, Tech |
| 03-08-2013, 07:57 PM | #110 | |
![]() ![]() ![]() 1176
Rep 567
Can you hear the engine? Yes, on a cold start, if you roll the windows down, you will hear the engine. I am not an audiophile so I personally couldn’t care less how a cold v6 sounds compared to a cold v4. Once you roll the windows up, the car is dead quiet (unlike 328 with the same engine). I read quite a few comments bashing the v4 (not necessarily in this thread), but they all sooner or later just boil down to a one simple conclusion, which is “(…) I have driven a v6+ all my life and I am not willing to spend 60k+ on a four banger”. Point taken, but then it becomes nothing else but just a personal mental thing (not that there is anything wrong with it). Large displacement cars are a thing of the past. It’s been like that in Europe forever and yes, they’ve always been true blue blood Germans. Yet, I understand how someone who all his life drove a v8 suburban with a square footage comparable to a “cozy” Manhattan studio may not feel the same mental comfort driving a faster and more economical v4. Good luck!
Current: 2024 540i MSport
Prior: 2021 540i MSport, 2018 540i MSport, 2015 BMW 528i MSport, 2012 BMW 528i ![]() Last edited by COBodom; 03-08-2013 at 08:06 PM.. |
| Bookmarks |
