2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes M5 Sway bar to 550i?
      09-13-2013, 01:01 PM   #221
badblack550xi
badblack550xi's Avatar
So i hear the Diesel 5 series rear sway is thicker than ours and is a direct fit ?
2011 550i RWD 60-130 7.35
      09-13-2013, 08:39 PM   #222
ClassM
Drives: BMW 535i msport/M5 E60/M3 E9x
Damn I have ARS cant rock a M5 sway bar. Good thing I got the real deal anyway.
      09-13-2013, 09:35 PM   #223
ausdude
ausdude's Avatar
Drives: 2013 BMW 550i M Sport
M5's cannot get ARS. There must be a reason
      09-13-2013, 09:36 PM   #224
ausdude
ausdude's Avatar
Alan L just purchased that sway bar and is installing it on his LSI 550
      09-14-2013, 10:12 AM   #225
sanyomats
Drives: 535, 328
So those F10s with ARS cannot do this mod? I was just abt to buy one today....
      09-14-2013, 07:08 PM   #226
HighConcept
Drives: F-Ten ///M
as mush as it was when i went from Run flats to Hankook V12's ?
Better.
Yes.
      09-14-2013, 08:52 PM   #227
TheBlackGT
Like No Other.
TheBlackGT's Avatar
Drives: BMW F07 LCI
Originally Posted by HighConcept View Post
Better.
Yes.
Does it work on an F07?
BMW 550i GT LCI (w/ a VW MK7 daily)
personal IG: http://www.instagram.com/TheBlackGT
my work: http://www.instagram.com/CorsaAutoDesign
      09-20-2013, 09:38 AM   #228
sbu1
Drives: 2103 528i x-drive
Has there been a determination what rear bar to upgrade to from a stock 528ix? Would like to match the upgraded M5 front bar as close as possible. Thanks in advance.
      09-20-2013, 11:20 AM   #229
remmib
remmib's Avatar
Norway
1643
Drives: 2013 F10 520d M-Sport
So you has the M5 front sway bar on you 528i xdrive? Then why didn't it fit onto Akkord29's 528i xdrive in post #213?
      09-20-2013, 12:13 PM   #230
Alan l.
Alan l.'s Avatar
6693
Drives: 2026 M5 Touring
My rear M550D/650 rear sway bar just arrived. Its 16mm and going to put it in my LCI 550 tomorrow. Stock size on my car is 14mm.
      09-20-2013, 01:00 PM   #231
sbu1
Originally Posted by FElleven View Post
Hm, all F10 have this Electric steering box, expect xdrive models from 530 upwards, which have hydraulic. joe@ptech have this fitted to his 550i with electric steering, so I doubt it wont fit yours 528ix bc of this control module.
I don't see why it won't fit the 528ix if this is an accurate assumption. I am going to get it up on the lift see when it comes in. If not, then check the classifieds next week for a deal on an M5 bar.
      09-20-2013, 04:43 PM   #232
HDEddie1
HDEddie1's Avatar
138
Drives: X5 40i, X3M40i, Audi SQ5
Even though the 16mm is only 2mm (or about 14%) larger, I suspect the difference will be felt nonetheless. I read a while back on a Porche post that the resistance factor was exponential to the increase in bar diameter. I just don't remember the formula or factor but nevertheless, I can't help but believe there'll be a benefit. Can't wait to hear your report.
Thanks...Keep up the good work!
      09-21-2013, 11:35 PM   #233
Alan l.
Alan l.'s Avatar
6693
16mm M550d/650 rear sway bar installed.
New bar on top, stock 14mm one on the bottom.
      09-22-2013, 11:31 AM   #234
mdrobc13
mdrobc13's Avatar
490
Drives: Made in Bavaria or nearby
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
where did you source yours from? rear sway bar I mean...I've already done the front sway bar replacement. Have a 2012 550i with M Sports package. Would it be a direct fit?
'23 BMW M2 (Z. Blue/black) - weekender, '22 BMW M4 Comp (SSG/Black) - gone, '16 BMW M4 (Shakir Orange/Black) - gone, '15 BMW M3 (Black/Black) - gone not forgotten,'10 BMW X5M (Black/Black) - gone not forgotten,'08 BMW M3 (Space Gray/Black) - gone, '03 BMW M3 (Black/Black)
      09-22-2013, 04:28 PM   #235
remmib
remmib's Avatar
Norway
1643
Looking at the pics, I assume it's the two new bushings (33556788630) in the plastic bags. And that's all you need, plus the sway bar (33556791932), right?
      09-23-2013, 12:09 AM   #236
528imsport
528imsport's Avatar
Drives: Msport
I have the 20" Hankook V12 on my car and very pleased with them, for that kind of price nothing can beat it.
      09-23-2013, 08:44 AM   #237
Alan l.
Alan l.'s Avatar
6693
Correct. All you need is the bar and two new rubber bushings and that's it. You can do the swap with a ratchet and jack stands in less than 15mins.
Alan
      09-25-2013, 04:48 AM   #238
LeoHK
Hong Kong
Drives: 2011 535i
Alan,
Do you feel the difference after swapping the rear sway bar from 14 to 16mm?
Swapping the front is more noticeable than swapping the rear?
I suspect swapping the rear will add "oversteer" to balance out the extra "understeer" added by swapping the front. Better feel when exiting corner?
I am planning to swap both front and rear at the same time, if the rear makes a different.
      09-25-2013, 09:12 AM   #239
Alan l.
Alan l.'s Avatar
6693
yes the rear does make a difference but not as dramatic as the front. Well worth the $190 price tag for the parts and the install for the rear is super easy.
Alan
      09-25-2013, 09:35 AM   #240
badblack550xi
LIKE A BAUS!
      09-25-2013, 03:31 PM   #241
Analog
Analog's Avatar
Drives: 12 F10 535 xdrive
Alan
I just put on the rear bar last week as well. Agree with what Alan said. Rear is less noticeable, but made the car handles better overall.
      09-25-2013, 08:50 PM   #242
528imsport
528imsport's Avatar
Drives: Msport
Alan
$190 is for the bar and the 2 rubbers right?
were can I buy?
