| 08-16-2016, 06:19 PM | #177 |
Supreme Allied Commander
13524
Rep 50,668
Drives: 2018 Alpina B6 650ix GC
If CAFD is missing or corrupt, you must Inject new CAFD into ECU and VO Code it:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on HKFM => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on HKFM (the ECU itself not the underlying CAFD) => Select CODE.
![]() 2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
| 08-20-2016, 04:32 PM | #178 | |
Dream crusher
1041
Rep 2,420
IG: @bmwdoubles |
| 08-26-2016, 01:58 PM | #179 |
Rep 8,407
| 08-28-2016, 08:38 PM | #182 |
Rep 11
Thanks for all the information guys -- Just did my first session and am hooked! Already was able to turn off landing disclaimer, show PSI on tires, disable driver seatbelt gong.
However I used the cheat sheet to set the folding mirrors, and set the below: CAS / KOMFORTSCHLIESSUNG_FB = aktiv (01) CAS / KOMFORTSCHLIESSUNG_PA = aktiv (01) But that functionality does not work. I also tried to hold 2 seconds and still doesn't work. Anyone have any tips to get that piece working to fold in mirrors on lock / fold out on unlock? I do have the comfort access package. Thanks! |
| 08-28-2016, 08:50 PM | #183 | |
13524
Rep 50,668
| 08-28-2016, 08:53 PM | #184 | |
Rep 11
Worth mentioning, when I did turn the values on KOMFORTSCHLIESSUNG_FB / PA, i had to overwrite the 00 to 01 on both, and one was already set to "aktiv". I got a success message after uploading, but I will look again tomorrow to make sure the values stuck. |
| 08-28-2016, 09:01 PM | #185 | |
13524
Rep 50,668
| 08-28-2016, 10:36 PM | #186 |
Rep 11
Interesting, I was going off of the cheat sheet which said to modify to 01. I'm not sure what VO Code is, any documentation on how to do that? I did backup the original maps so worst case I will revert the files.
| 08-28-2016, 11:21 PM | #187 | |
13524
Rep 50,668
Only change Werte values directly if and when the Drop-Down box of predefined values does not have choice you need. Just Right-Click on CAS Module (the ECU itself and not the underlying CAFD) and Select Code to reset it, then go back and make your FDL Changes using the Drop-Down box of predefined values.
| 08-30-2016, 11:13 AM | #188 |
Dream crusher
1041
Rep 2,420
It ended up working, eventually. On the second time I turned the car on. Don't know why that was. The only thing is you can't dim it and map day/night mode doesn't work. I ended up programming a button for day and night map modes.
IG: @bmwdoubles |
| 09-04-2016, 03:51 AM | #189 |
Rep 8,407
Some coding (eg, close trunk via FOB) requires shutting down the car for 15-20 minutes. Other coding (eg, anything involving head unit) is effective immediately.
| 09-04-2016, 08:05 AM | #190 |
![]() ![]() 153
Rep 345
Morning everyone! Been looking to start coding a few things on my own and would appreciate if anyone can provide info on where to get software from for my 2013 535iX.
Thanks and hope everyone is having a great Labor Day weekend!
Current: 2013 F10
Previous: 2007 E90 Previous: 1994 E34 ![]() |
| 09-04-2016, 08:34 AM | #191 |
13524
Rep 50,668
PM sent.
| 09-04-2016, 11:16 AM | #192 |
Rep 5,058
Curious, do you know if the M Performance logo on start (KOMBI) works in MY16 F10? Wasn't listed on any of the printed F10 cheat sheets, but I see it listed as a cheat option in esys launcher.
current 2024 i5 | 2024 530i | 2026 X5 M60i
retired 2023 840GC | 2021 740i | 2019 540i | 2019 X3 30i | 2017 540i | 2016 535i | 2015 535i | 2014 335i | 2013 335i | 2010 335i | 2007 750Li | 2006 330i | 2003 330iC | 1997 M3C |
| 09-04-2016, 02:06 PM | #193 |
Rep 8,407
The different options will result in various images, but not desired M performance.
| 09-04-2016, 02:16 PM | #194 | |
Rep 1,263
| 09-28-2016, 09:45 AM | #196 |
13524
Rep 50,668
PM sent.
| 09-28-2016, 04:52 PM | #197 |
Rep 35
Drives: 2013 528i
Hello, Could I get a link to the most recent version of PSdZData files?
Thanks! |
| 09-28-2016, 05:14 PM | #198 |
13524
Rep 50,668
PM sent.
| Bookmarks |
