Retrofitting 4 Zone Climate Control on My 2016 BMW 550i xdrive
Thread Tools |
| 10-07-2022, 09:33 PM | #45 | |
![]() 66
Rep 253
Do you know if the wiring for the rear heated seats are there because i read that the wiring to the heated seats has to also be changed during this 4 zone climate control retrofit? Also do you have the wiring diagrams? Last edited by SocomCA; 10-08-2022 at 10:50 AM.. |
| 11-16-2022, 06:33 AM | #46 |
Rep 2
Thank you for verifying your account!
In order to use the PM system and be a full fledged member of this community, you will have to make a certain number of verified post replies and wait 7 days for your account to be upgraded. |
| 11-16-2022, 06:39 AM | #47 | |
Rep 2
Unfortunately, I don't have a wiring diagram, I haven't gotten it yet! I'm a bit worried about the two different rear climate controls (fan and fanless), since i was originally without a fan, will it work with the fan version, will it be programmable? Thanks |
| 06-06-2023, 12:19 AM | #49 | |
![]() 66
Rep 253
I just realized, you didnt include Auxiliary heater, electric, left: #64119217997 Auxiliary heater, electric, right: #64119217996 https://www.realoem.com/bmw/enUS/sho...48#64119181331 Did you install these too? |
| 06-06-2023, 12:31 AM | #50 | |
![]() 952
Rep 1,231
They have both the heating elements, and temp sensors in them...so those are necessary for error free factory operation.... Good catch. |
| 06-06-2023, 01:15 AM | #51 | |
![]() 66
Rep 253
Did you take pictures of your install during the install? Also do you know if the rear screen controller will work without the hvac install? i want to hold off on the hvac install until later and plan on installing the center console blower motor + climate controller with screen + foot well sensors and wiring. Will i be able to control anything with the climate controller without the 4 zone hvac change?? I don't plan on doing the b pillar install or carpet change |
| 07-09-2023, 06:46 AM | #52 |
![]() 0
Rep 42
Sorry need todo a question
Its extremely hard to find Interior Heaters 2hand- Distribution housing, a/c unit, lower 64119241199 Searching for F10/F11 with 4 Zones, I have been finding that a lot have 11 actuators instead of 13. With 13 i could only find one of endless weeks searching. - They are not expensive 50-100€, the transport is expensive +100€ This two are controlled by the top actuators. - 11 Actuators ![]() ![]() M23 M22 But i can also find in TIS that F01 + F02 + F07 had M22 + M23 = 13 Actuators. Confuse there are 2 versions of 4 Climate Zones? The other point is For F10/F11 LCI the Distribution housing, a/c unit, lower that supports the actuators is the following Autom. climate control with 4-zone ctrl S4NBA=Yes Distribution housing, a/c with preheater 1 03/2013 64119241199 ![]() The only Cars compatible are F06 Grand Coupe ![]() If I try to buy a brand new Distribution housing with 4 Zones, it comes with support for 11 Actuators not 13. But If we look at the actuators needed ![]() Maybe we can assemble 13 instead of 11 and all i need todo is adapt the wiring. https://www.newtis.info/tisv2/a/en/f...ion/1VnbhzL6Ge Last edited by Napas; 07-09-2023 at 07:19 AM.. |
| 07-09-2023, 08:36 PM | #53 | |
![]() 952
Rep 1,231
The rear HVAC controller (FKA) is a slave to the front HVAC controller (IHKA), and needs to be coded for it to function 100%. Not doing so will have unpredictable operation, so not sure I can provide a definitive answer, but since the adjustments in the FKA is done for flap adjustments, which is controlled through the IHKA, minimally you may not get the intended air flap operation. Leaving off the B-pillar HW will have almost no ill effect on the system. I wish I hadn't done it myself, but since I did, it's staying installed. Last edited by M_Bimmer; 07-09-2023 at 08:45 PM.. |
| 01-14-2024, 12:39 AM | #54 | |
![]() 66
Rep 253
So im thinking of only doing the partial 4 zone climate control retrofit mainly to increase the air flow for the rear while keeping the original heated seats function but without additional footwell heating modules or anything. According to this thread, they said: https://www.bimmerfest.com/threads/2...ir-con.828555/ Parts: Front grille with 4 zone climate control 64229166891 Rear Center Console Cover 51169206781 Rear Blower 64119311853 Rear Center grill 64229172344 4-zone rear controller w/ seat heating, w/o ceramic knobs - 61319290751 4-zone center console, storage compartment (qty 1) - 51169206729 On the electrical part 1) Connectors and cable from rear center control unit to the rear center grille vent. 2) Connectors and cable from the rear blower to the rear center control unit. 3) Power for the rear center control unit to be taken from the front fuse box (behind the glove box). 4) Power for the rear blower to be taken from the rear fuse box (at the trunk). 5) Power for the lighting on the rear center grille vent to be taken from the LED lighting for the center storage box. 6) Connection to CAN bus. 7) For heated rear seats, run LIN bus wires from the two rear seat heater controllers to the JBE. Is there anything else I'm missing to accomplish just control air flow from the center console blower to increase the airflow based on what the front driver setting is? |
| 01-14-2024, 12:16 PM | #55 | |
![]() 952
Rep 1,231
If you are asking me how to get the rear climate controller to "just" control the center console fan speed, I have no idea. The system is complex and with my Engineering background, I couldn't convince myself that a predictable functionality could be achieved with only a partial installation.
If you proceed, and are successful with a partial install of the 4-zone, please post. Others most certainly would LOVE to hear about your accomplishment. The "others" that post on partial install, oddly, don't post anything afterwards on what does or doesn't work. Last edited by M_Bimmer; 01-14-2024 at 12:22 PM.. |
| 06-15-2024, 11:31 AM | #56 |
![]() 1496
Rep 2,684
For those who already have automatic climate control, you don't need to get the front side vents replaced (64229166889/64229166890 in post #4)****. Also, in my search for parts, salvage yards almost always sell the distribution housing upper and lower as a single unit, which will include all the motors and temp sensors you need for the front distribution housing. Look for parts ideally from a RR, since 4 zone climate is standard on those cars and you don't need to worry about salvage yards misidentifying the parts.
The hardest part on this retrofit isn't really the wiring itself, newTIS wiring diagrams are genuinely easy to follow, but rather sourcing the right plugs and pins. I am planning on tackling this retrofit soon and managed to find a guy in Poland who was selling a wiring kit for 4 zone climate retrofit specifically, and will post pictures of the various plugs and pins once I get the harness. Edit: ****: Turns out, realoem lies. I removed my front side grilles and they have no accommodations for wiring. Looks like you will need to buy part # 64229166889/64229166890 after all Edit 2: But on newtis, it appears that the front side vents having any wiring is a 7 series specific thing?? Honestly I dunno at this point. Maybe M_Bimmer can shed some light. Edit 3: Digging more on newtis, it appears that the wiring on the 4 zone climate specific side vents is just so the knob can...light up? That seems hilariously useless.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial Last edited by Unspec; 07-13-2024 at 11:36 PM.. |
| 07-13-2024, 10:38 PM | #57 |
![]() 1496
Rep 2,684
M_Bimmer did you use part # 64229227657? Didn't see you mention it
2015 BMW 535xi
| 07-13-2024, 11:40 PM | #58 | |
![]() 952
Rep 1,231
It's been a while since I did this conversion, that I do not remember all the exact differences between the non-4-zone center console, and the 4-zone center console...and then the pre-LCI vs LCI differences. Honestly, I know many have posted that this is not a worthwhile mod.....but it was. Often the rear passengers require a different temperature than those in the front, so they appreciate that they can control the airflow and temperature to suite them. |
| 07-14-2024, 12:08 PM | #59 | |
![]() 1496
Rep 2,684
2015 BMW 535xi
| 07-14-2024, 02:27 PM | #60 | |
![]() 952
Rep 1,231
Not installing the B-pillar vents is the only 4-zone feature that will NOT throw a BMW code once VO code SA4NB is enabled. I initially thought I had an air blockage in the F10, but my F02 & G12 B-pillar air has weak air flow too (non-detectable air flow). Even with the rear fan on 100% (lots of noise, but literally zero CFM), all the air tends to exit the rear center console vents (least air resistance). (Note: The rear floorboard vent stratification is controlled by the front air distribution box, where as the b-pillar air flow are predominately influenced by the center console rear fan. So you can get really good floor board and rear center vent air flow depending on stratification configuration....but the b-pillar air vents are sort of worthless, even if you close the rear center vents) |
| 07-17-2024, 10:35 PM | #61 | |
![]() 1496
Rep 2,684
2015 BMW 535xi
| 07-17-2024, 11:08 PM | #62 | |
![]() 952
Rep 1,231
I guess I could have purchased a used rear carpet, for 4-zone, from eBay, but inheriting someone's rear floor mess was not appealing. Rear sunshade, 4-zone and rear heated seats were mods well worth it.....was debating on adding rear seat ventilation from an F02...... |
| 07-21-2024, 11:33 AM | #63 | |
![]() 1496
Rep 2,684
Edit: The rear climate control panel with the button for ventilation is also god awful expensive for some reason: https://www.ebay.com/itm/387164435440 Almost $600!
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial Last edited by Unspec; 07-21-2024 at 11:39 AM.. |
| 07-21-2024, 01:16 PM | #64 |
Rep 12
HKA Wiring
Below is the wiring schematic for the HKA (A39) module in the F10/F11 and the F01/F02 4-zone climate control.
Very simple. 1. Can BUS wires link the HKA with IHKA (Front Climate Controller) 2. 12VDC power from the rear fuse box 3. Single PWM wire to the rear blower 4. Several wires over to each floorboard rear heater/stratification/temp sensor 5. 2 wires for the orange button/display 6. 2 wires for ambient lighting (B58 only) Note: If you are replacing the rear panel than has only heated seat buttons, with an A39 module, once coded for 4-zone, A39 will drive the rear seat heating modules |
| 07-21-2024, 02:42 PM | #65 | |
![]() 1496
Rep 2,684
2015 BMW 535xi
| 08-06-2024, 04:32 PM | #66 | |
![]() 1496
Rep 2,684
I am unsure why there's a part number difference between the F10 4 zone lower and 4 zone lower used for the other listed models - even though the F07 is also just a 5 series. Maybe two different factories for the same part, and so they just gave one part number to half the applicable vehicles, and another part number to the rest? Dunno.
2015 BMW 535xi
| Bookmarks |
| Tags |
| climate control, f10 |
