Best way to remove swirls from black plastic exterior trim
Thread Tools |
| 04-02-2026, 06:00 AM | #1 |
Rep 25
I’ve been extremely careful in caring for the black trim surrounding the windows, beneath the grille, and even the rear taillights on our ‘26 50e M Sport, but inevitably, there are a few swirls/scratches starting to pop up. It happens and will continue to happen, so not overly freaking out about it, but I’m curious what the best way to remove those scratches/swirls is aside from replacing pieces over time. Again, not going to do it every weekend or sweat every little thing, but if I wanted to remove a bunch of them at once, what’s the best way? Is there a way I can PPF those pieces also? The pieces beween the A and B pillars tend to be the most noticeable at eye level in particular. Thanks!
| 04-02-2026, 08:17 AM | #2 |
![]() 4430
Rep 2,354
Drives: BMWs, duh
Piano black plastic is the material of the devil and is going to scratch if you even look at it. You can polish it, and I've found that Meguiars PlastX works well. However, it's not going to last very long.
The only real way to prevent the scratching to is to put PPF on it – I just had that done yesterday to the piano black in the interior of my Z4. Otherwise you just need to learn to live with it, because you're not preventing it. Maybe one day car manufacturers won't use the goddamned stuff, but today isn't that day. |
CGG348.50 Jschmidt68425.50 |
| 04-02-2026, 08:39 AM | #3 |
![]() ![]() ![]() 569
Rep 555
Polish and PPF.
Also not sure on your washing techniques but wash in straight lines vs circles and never run it through a carwash unless it's touchless. |
Jschmidt68425.50 |
| 04-02-2026, 11:02 AM | #4 |
![]() 207
Rep 173
You can indeed polish them and see improvement. But the truth is, the more flawless you make the surface, the more obvious imperfections are on them. Even fingerprints stand out more on pristine piano black, so be careful of the slippery slope this creates. Haha.
I use the Adams SK Micro for polishing these. (But there are cheaper options, as well as nicer ones too. This is a good mid tier polisher). https://adamspolishes.com/products/a...40098604580961 You could apply PPF as others have mentioned, but as there’s no edge to wrap around, you’ll likely see some edge lifting over time. Particularly with these being touch points. |
Rick Danger43.50 Jschmidt68425.50 |
| 04-02-2026, 03:17 PM | #5 | |
Racecar Driver
2143
Rep 2,901
Drives: BMW M4
You don't need to do the stage 1 paint correction as it should instantly mask it like this. View post on imgur.com
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
Phillies80084429.50 Jschmidt68425.50 |
| 04-02-2026, 03:40 PM | #6 | |
![]() 207
Rep 173
It’s generally referred to as a 1 stage paint correction (not stage 1). When correcting in multiple steps (stages), you go from most abrasive / most coarse to least abrasive / finest. So a single stage correction is typically just a fine abrasive, usually referred to as a polish. |
Jschmidt68425.50 |
| 04-02-2026, 04:32 PM | #7 | |
Racecar Driver
2143
Rep 2,901
Drives: BMW M4
N1rve
| 04-03-2026, 12:05 AM | #8 |
![]() 207
Rep 173
| 04-03-2026, 12:20 AM | #9 | |
Racecar Driver
2143
Rep 2,901
Drives: BMW M4
N1rve
| 04-03-2026, 01:25 PM | #10 | |
Rep 28
Southeast198.00 Jschmidt68425.50 |
| Bookmarks |
