2010 2011 BMW 5 Series Forum F10 What did you do to your 5 series today? |
05-18-2022, 11:43 PM | #2619 | |
Rep 240
Drives: 2015 BMW 535i M Sport
(Was getting Increased Battery Drain While Stopped Code when I would leave my car parked for 2+ days during heavy rain - ended up being CA short) https://smartercharger.com/products/ctek-mxs-5-0 |
StradaRedlands5035.00 |
05-21-2022, 11:57 AM | #2620 |
Rep 3,089
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.25]
2009 BMW 328i Touri ... [8.00] 2013 BMW X5 35i [7.80] 2011 BMW 528i [8.70] 2006 Mazda3 [5.50] |
Installed blacked out rear reflectors. VERY happy with them. They are actually LED lights that can be wired into the brake lights, but that's probably not going to happen. Need to do something about that shiny license plate frame.
ctcarbonari305.50 |
05-22-2022, 12:55 PM | #2621 |
BMW enthusiast since 2004
375
Rep 191
Washed it and steering wheel heating retrofitted.
05-28-2022, 03:11 PM | #2622 |
375
Rep 191
xhp stage3 installed, transformation is amazing. I'll just hope soon I have time to do the timing chain and after that ecu tuning and more out of the N47.
05-29-2022, 01:09 PM | #2623 |
Rep 30
Installed new rear wheel steering HSR actuator:
05-30-2022, 11:43 AM | #2624 |
375
Rep 191
Installed sport shifter. Just needed new connector and repin it. |
05-30-2022, 01:54 PM | #2628 |
375
Rep 191
05-30-2022, 03:13 PM | #2629 |
Rep 5,409
06-02-2022, 01:49 PM | #2630 |
Rep 188
Cross drilled rotors and EBC Redstuff pads installed all around.
06-05-2022, 11:09 AM | #2631 |
Rep 274
Which rotors are these? They look like they have an aluminum hat?
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #578262 as a referral.
F10 535i M-Sport | Gone but not forgotten: G01 X3 xDrive30i M-Sport; F15 X5 xDrive35i; E70 X5 4.8i |
06-05-2022, 11:27 AM | #2632 |
Rep 188
Cquence is the company who makes them. From this angle, it does look like an aluminum hat on it but it's just a normal looking rotor.
06-06-2022, 12:05 PM | #2633 |
Rep 1,156
Finally gave her a proper spring cleaning/scrub down.
2014 550i Dinan Stage 3 Dinan Shockware Meisterschaft Mufflers/m5 comp package xpipe ACS Springs OEM 343m (m5) wheels 285/255 (trying to get 295's in the back still) Last edited by xxpanipuri; 06-06-2022 at 12:22 PM.. |
cdmulders330.50 StradaRedlands5035.00 |
06-06-2022, 01:46 PM | #2634 |
375
Rep 191
Test fitted winter wheel. I guess style 302's will work fine for winter, now gotta figure what tire to put. Thank god winter isn't even close yet.
I will lift it 1-2cm for winter also. |
06-06-2022, 03:35 PM | #2635 |
Rep 7
N55 engine bay
06-06-2022, 07:35 PM | #2636 |
Rep 1,363
New pad and rotor due to uneven wear and started to squeak slightly. Somehow outer side have about 25% while inner side have about 50% on the same corner.
06-06-2022, 11:56 PM | #2637 |
Rep 3,089
06-07-2022, 06:57 AM | #2638 |
Rep 1,363
I don't think so. I was able to retract and push it out easily by spinning it from the back. Guide pins moves freely as well. We will see what happens in the future. Hopefully it's nothing
06-11-2022, 12:06 PM | #2639 |
375
Rep 191
New transmission mount. Cortego looked like OEM.
06-18-2022, 03:40 AM | #2640 |
Rep 3
cruise control switch was worn. Support wants 200€ for the 10€ part.
Well, that's what I did: |
