2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications G Plus F10 Intercooler
      05-26-2019, 02:29 PM   #67
gpabalinas81
Drives: 2014 535i M Sport
Originally Posted by lsturbointeg View Post
Very nice. Are you able to get pictures during the install or maybe a good DIY
Photos for sure during the install, i'll see about the DYI!
2014 535i M Sport Mods: BMS Intake, FTP Charge Pipe, FTP Boost Pipe, G-Plus FMIC, JB4, Remus Sport Exhaust with 84mm Black Carbon Tips
      05-28-2019, 11:18 PM   #68
Casebrius
Drives: 2016 535 M-Sport; 95,97 E36 M3
Does this allow for the undertray to go back on?
      05-29-2019, 07:51 AM   #69
ziekxq
Drives: 2011 535i xDrive
Looks a lot thinner than Wagner or VRSF.
      05-29-2019, 07:10 PM   #70
gpabalinas81
from what i have been reading, the wagner and this unit are the same dimensions, intall pics to follow, having it installed Friday.
      05-29-2019, 07:12 PM   #71
gpabalinas81
Yup, you'll be able to re-install the under shield once installed
      05-30-2019, 09:31 AM   #72
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
Underbody tray, yes. The tray the used to cover the bottom of the intercooler, no. The bottom of the intercooler sits about half an inch lower than the OEM one. I just tossed it after the install, not like you actually need it for anything.
      06-03-2019, 07:56 PM   #73
gpabalinas81
So I got this mofo installed with my BMW Buddy on Friday, not as easy as it seems, fitment is TIGHT!!!, had to cut off some plastic on the back side of the radiator to get this thing to fit, it eventually fit with some manipulation, getting my hand stuck between the crossmember and pipe and a few cuts, but me and my buddy got it in. He was at the point that he was going to take the whole front end apart. Overall works, but we broke the "c" clip that goes from the boost pipe to the intercooler (the one on the passenger side) we changed out the stock boost pipe to a FTP since I had it / came with my Charge pipe as a combo, and we had the intercooler out, do you know if BMW sells replacement ones?? I can't find any of these clips online, only found the clip to the Charge pipe that goes to the throttle body. Any help would be greatly appreciated. Sorry, I didn't take pics, I ended up helping my buddy do the install, so my hand were greasy
      06-03-2019, 10:46 PM   #74
top ramen
Drives: Schwarz II 535i
Did you follow bullits5 DIY that he did on this same intercooler? He said it was tight but his went in with no modifications.
Here's his DIY, it's a great write up
https://f10.5post.com/forums/showthread.php?t=1596580
      06-04-2019, 08:33 PM   #75
gpabalinas81
Yah, I followed his post, stock intercooler came out no problem, but when installing the new intercooler and new boost pipe, that's where the problem came, you have to get the boost pipe at the right angle or else it wont go in. It was stiff as hell hard to turn, we loosened up the clamps that connect the the boost pipe together, there's and end piece that goes to the intercooler, a rubber coupler then then pipe that connects to the turbo, if you dont get the angle correct, your F!!c15ed! We were able to get it in, but that damn c clamp that connects the boost pipe to the intercooler broke......
      06-05-2019, 10:10 AM   #76
tkatz2214
Drives: 14 F10 N55 (M) 17 F15 N55 (M)
For those who have this FMIC installed, any signs of boost loss compared to the OE IC? Its a great deal and clearly temperature is not an issue, but what about the boost? If it is losing 5 psi boost across it, that may be a huge difference that wagner beats it on?
      06-21-2019, 05:30 PM   #77
jonobro
Drives: bmw f10 535i
Originally Posted by rencxgreg View Post
Received mine today, it looks quality but seller on the eBay did not send me the mounting bracket and screws. I already sent a message to the seller and did not receive any reply yet.
Debating on getting this, how do you like it so far ? You have a F10 correct ?
      06-21-2019, 05:48 PM   #78
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
dont know about Gplus but for wagner.. if you get on it alot the IAT will just go lower at the end of the run.... lower IAT the better for the car...
      07-09-2019, 01:18 AM   #79
trialmountain
Drives: F10 N55 - EWG
Just received my G-Plus intercooler... with a dent in the coupler. Otherwise it looks good to me! Brackets were included.
2015 F10 535i | BM3 STG 2 91 Octane | VRSF 4" DP | GPlus FMIC | Eibach SwayBars | H&R Springs | NGK 97506 .020"
      07-21-2019, 09:39 PM   #80
gendong
Malaysia
Drives: BMW F10 535i
So how's the IC so far? Holding on well?
      08-14-2019, 09:09 AM   #81
trialmountain
More real data for people looking to make a decision between Wagner or G-Plus. 4th gear log attached. IAT initially drops but then climbs by about 10° by the end of the pull. I am unsure how this compares to the Wagner or VRSF.
http://www.bootmod3.net/log?id=5d540f15c090c638743c4f0d
This was done right after doing a 5th year log where the IAT dropped slightly then went up a few degrees.
http://www.bootmod3.net/log?id=5d540eb2c090c638743c4f09
My uneducated conclusion: works great for the price! The others may or may not perform better. It appears the G-Plus does like to retain some heat after repeated pulls but does not allow IAT to climb into an area that will pull timing.
      08-14-2019, 11:40 AM   #82
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Thanks for the update! What did you do about the bent coupler? Will that cause a leak under boost? Does the car run cooler? I'm wondering it they have an aftermarket radiators for the F10 and I don't mean OEM. Rather aluminum radiator
      08-14-2019, 03:36 PM   #83
trialmountain
They promptly sent me a new intercooler, even before I sent the old one back. The new one was in perfect condition. It probably would not have caused a leak but it's a non-issue now.
Coolant and oil temps are unaffected by an intercooler in this application. I'm sure someone makes an aftermarket radiator, but I do not see the need. The biggest concern we have with F series N55 is the small stock intercooler not being able to keep Intake Air Temp(IAT) down. G-Plus has solved that for me and hard daily driving. I'll monitor if/when I do an autocross with this car.
      08-14-2019, 03:41 PM   #84
lsturbointeg
in a different thread they talked about lag because of the intercooler. specifically the Wagner but i'm wondering if that's only because of the PureTurbo2 upgrage? i'm guessing with a stock turbo the G Plus should be fine? again, thanks for the reply. oh, did you upgrade any of the intercooler piping?
      08-14-2019, 06:03 PM   #85
trialmountain
No lag was detected. Perceived lag could be there now that the turbo comes on much stronger, but it's not "lag". I would not expect that from this size of intercooler. It's bigger but not huge.
I do not have any real life experience with PS2, but any time it takes more airflow to spin something there will be some correlation to how long it takes to reach peak boost. That said, it's a stock housing upgrade and any lag caused by it wont be much from the logs i've seen.
I did not upgrade the any other piping. Stock chargepipe and boost pipe.
      08-15-2019, 11:55 AM   #86
burro_blasta
Drives: 2013 535 M Sport
Agreed - maybe a little bit more lag after installing the Wagner but nothing to worry about (I'm stock PWG)
      08-15-2019, 12:56 PM   #87
Unspec
Unspec's Avatar
1301
Are you referencing this thread?
https://f10.5post.com/forums/showthread.php?t=1495900
If so, the guy found his lag issue, wasn't related to the intercooler.
      08-15-2019, 01:19 PM   #88
lsturbointeg
No. I saw that thread. I think his issue was related to his install
I was referring to another thread where a member upgraded his turbos to Pure2 and with the Wagner IC he noticed a bit of lag. I believe he resolved the issue. I was asking a clarification if us guys with stock turbos and an upgraded IC would notice lag?
