11-22-2014, 02:44 PM | #1 |
Rep 184
Can anyone recommend a torque wrench?
Can anyone recommend a specific general purpose torque wrench? I'd like a nice one that will last forever and can do 0-? lbs... Would rather not buy one for low tension applications and another for more... Good quality, decent value - don't need hand forged, damascus steel, bomb-proof... I'm going to drop in some BMC air filters and the cf strut brace is just one of the millions of things I've needed a torque wrench for and not had... Thanks.
11-22-2014, 03:16 PM | #3 |
Rep 480
I have one made by Titan - It's pretty good, I used it to swap springs one time and most use it to torque my wheels on and off. I wouldn't use it for building an engine, but for most stuff when you only have to be close to accurate it's good.
11-22-2014, 03:53 PM | #7 |
Rep 184
Thanks guys - now which "type" of torque wrench? The click kind? or the old fashioned type that guys use in bike shops? Also, will these standard torque wrenches accept a socket to remove our wheels? While I'm at it, might as well kill two birds with one stone - what about a jack? If I want to change out my wheels on my own, what is the best way? I don't want to screw up the side skirts or anything.... floor jack?
11-22-2014, 04:15 PM | #8 |
Rep 617
I like my Snap-on torque wrench. Here is an eBay ad to the one I use. I use this one for wheels and bigger stuff I need torqued.
http://www.ebay.com/itm/Snap-On-1-2-...=US_Hand_Tools I have another one that I use for smaller applications. |
11-22-2014, 08:11 PM | #10 |
Rep 3,834
You don't need a high-end torque wrench to do suspension work. Being off by +-3ft lb is fine. Craftsman should be only off about +-4%. The more you pay, the more accurate it gets (like Snap On). Unless you're rebuilding your engine block or heads, you don't need it to be more accurate than that. Save your money and stick with Craftsman, lifetime warranty and no questions asked for warranty swaps.
11-22-2014, 08:21 PM | #11 |
Rep 969
I dunno if I would actually recommend it but I've had mine from Harbor Freight for years and have had no problems with it. $10 with a coupon from the flyers lol.
11-22-2014, 08:42 PM | #12 | |
Rep 2,928
Drives: 328i, 335i, M3, 535i, X5, 36M
Garage List 2014 Ford Raptor [0.00]
2012 328i E92 [10.00] 2013 X5 [0.00] 2013 335i F30 [8.00] 1990 Toyota Previa [0.00] 1997 E36 M3 [10.00] 2011 E92 M3 [0.00] 2011 535i [0.00] |
11-22-2014, 09:40 PM | #13 |
Rep 981
This. All you need to know is that Snap On sources theirs from CDI. I have 2 and so far so good. I'd go with the click just to make life easier/ cheaper. Make sure you store it with the tension set at the minimum or you can prematurely wear the mechanism.
11-22-2014, 09:44 PM | #14 | |
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
But have a feeling you meant Precision Instruments. I've been using the 1/2", and 3-piece 3/4" drive tools, split beam design so you don't have to turn it down like the HF and Craftsman's style barrel wrench which will lose it's accuracy and then what good is it for? The wrench is only as useful as it's calibration. $10 torque wrench? Why bother, I'd trust my muscle memory before those things. I spend enough time at the track to see lugs come off from being under torqued and lugs shear from being over torqued, not worth saving a few bucks over. The 1/2" can be had for $140. http://www.torqwrench.com/tools/C.php http://www.garagejournal.com/forum/s.../dp/B002XMSFIM http://www.amazon.com/s/ref=bl_sr_hi...ts&node=228013
F80 M3 / Mineral Grey-Silverstone / CCB
11-22-2014, 10:36 PM | #15 |
Rep 1,136
11-23-2014, 12:23 PM | #17 | |
Rep 737
I've checked it against a friends snap-on and it "seemed" right on. I've never felt "unsafe" or "unsure" of bolt torque from its use. If you were going to rebuild a motor, I'd suggest a higher end torque wrench as connecting rod and head bolts require alot more precision. But even then, the manufacturers usually give you a 2-3 ft-lb tolerance. |
11-24-2014, 06:34 AM | #19 |
Rep 570
Floor Jack
You'll get a lot of opinions here, too.
Regardless - don't forget to purchase the adapter for the jack head to the BMW jacking points, unless you already have it! http://www.ecstuning.com/ES251251/?g...Fcvm7AodBRYAoQ |
11-29-2014, 06:22 PM | #21 | |
Rep 184
11-29-2014, 10:05 PM | #22 | ||
Rep 969
