06-16-2015, 09:19 PM | #1 |
Rep 1,065
Leaking windshield fluid
Got the notification I was out of windshield fluid so I filled up at the gas station and by the time I got home it was empty. It started to leak on the floor from under the right splitter. Should I bring into BMW? Has this happened to anyone?
06-17-2015, 01:11 PM | #3 |
Rep 6,720
Windshield fluid is considered a consumable, and I do not believe it is covered. If you just rolled up and asked for gas, I don't think they'd give you that either.
Having said that, you're talking about a leak...which is covered by warranty, not maintenance, but should definitely be BMW's responsibility. |
06-17-2015, 01:18 PM | #4 |
Explodes on impact
209
Rep 552
Definitely bring it to BMW. They can't ding you if your fluid reservoir is clearly leaking.
Yea... yea I got an M(azda)3.... <.<
*work in progress* |
06-17-2015, 02:06 PM | #6 |
Explodes on impact
209
Rep 552
I remember reading somewhere here that long as it doesn't mess with what needs work, some BMW dealers wouldn't care less. Unless you did some aftermaket mod to squirt that fluid harder :3
06-17-2015, 02:17 PM | #7 |
Rep 1,904
06-17-2015, 02:35 PM | #8 |
Rep 8,631
Tank leak or leak from the hose that connects to or leak from the pump connection to the tank... classic BMW problem... if it's like every other BMW remove front right wheel well and take a look at what's leaking... albeit if u have warranty, I would run to dealer asap.
06-17-2015, 05:33 PM | #9 | |
Rep 664
2021 BMW M3 Comp
2021 BMW X3M 2018 BMW M3 - SO/SS ZCP - Gone 2017 BMW X5 40e M-Sport - Gone 2015 BMW M3 - Gone - ED Pickup June 2nd, 2015 |
