10-14-2017, 09:03 PM | #1 |
Rep 3,140
Drives: 2014 M5 6MT
Steering "knocking" at low speeds
Ok so I have a weird situation to report and or get advice on.
About 6 months ago I started noticing a knocking sound coming from my steering column/rack/ wheels etc. Only notice it when sitting still and or at low speeds ( < 20mph). The absolute most notable way to feel/hear the noise is when the drivers front wheel is riding the little reflectors on the center line, and at low speeds. It makes my whole car feel like the steering and suspension is falling apart. The noise is not present when going over normal road bumps, cracks, pot holes etc. All of my suspension and steering components are tight, no play whatsoever. In the last 3 months I've replaced the inner and outer tie rods and had a new, OE alignment. The issue has remained. I've inspected the obvious, and had another tech help me narrow it down. With the car on the lift, and no weight on the tires, you can rock the steering wheel back and forth about 20 degrees. It feels like steering play. The other tech could feel the knock in the rack and pinion. And couldn't see any obvious slack in the lower steering shaft assembly. I know this is a long shot, but Im trying to be as descriptive as possible. If anyone has had experience with something similar and can give me an idea of what else to check, Im all ears. Edit: I found a thread on the X5 forums about adjusting the preload on the rack and pinion gears. It seems to fix the very common ( For the E70), and exact issue Im having. Im going to give that a swing, and report back asap.
2014 M5 6MT
10-15-2017, 01:28 PM | #3 |
Rep 10,633
I get it. Feels a little like gravel in the rack or looseness. Only notice sometimes at very low speed. My upper strut bearings are only about a year or two old. Retorqued the rack bolts. Did separate rack from shaft to do rod bearings about 3 years ago. Maybe I did something wrong then?
10-15-2017, 01:53 PM | #4 | |
Rep 3,140
Drives: 2014 M5 6MT
2014 M5 6MT
10-14-2020, 06:13 PM | #5 | |
Rep 2
Anyone know about the replacing this part 32106891974 to fix the knocking problem? |
