BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > Canada
BPM
      04-08-2009, 09:32 AM   #1
markymarc1979
Drives: 16 G12 + 15 F06 + 17 F15
2009 BMW E93  [0.00]
2012 BMW 750xi  [0.00]
Need assistance with removal of stock orange reflector
HELLLLLPPPP!!!!
I tried to remove the stock painted reflector and it wouldn't budge. I don't want to keep jamming a screwdriver in between the reflector and the bumper. I checked the DIY for this and it's pretty lousy. Can anyone give any pointers on how to properly remove the painted reflector.
Any help would be greatly appreciated.
      04-08-2009, 09:51 AM   #2
flyguy
flyguy's Avatar
Drives: E92 335xi, Alpine White
Would also like to see response to this
      04-08-2009, 10:16 AM   #3
aw_330i
Drives: 2016 AY M4
i didnt use a screwdriver. What i did was push on the bumper under the relfector, then i had enough room to stick my fingers and sort of push the reflector towards the top right corner. I did use a bit of force but everything came out fine.
It was almost like i was pulling on the reflector up and out.
HTH
      04-08-2009, 11:26 AM   #4
schnell325
Bored at work....
schnell325's Avatar
Drives: 2016 F82 M4 GTS//2022 M235iGC
Uggg.....same issue here. I'm almost tempted to wait until the temp is ~25C to do this.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD!
Anti Matter :2016 F82 M4 GTS
What next?!? A 2022 M235i GC- I must be getting old
      04-08-2009, 11:57 AM   #5
Jaypod
Jaypod's Avatar
Drives: Frozen M3, AM V8V, 991 GT3
When I did mine it was cold (even in my Garage) The bumper did not have much play. I was able to wedge underneath with my finger a thin platic card (cant remember might have been the aeroplan card). I put a microfibre cloth behind it. Once I was able to get the bottom of the reflector come out a bit I was able to push up on it and it popped out pretty easy. You could also use a flathead screwdriver rested against the card to make it easier. The second one seemed much easier (passanger side).
All for not though - no more reflectors for me!!!!
      04-08-2009, 12:31 PM   #6
Alex///M
E90 - the Ultimate family hauler
Alex///M's Avatar
Drives: 2008 E90 ///M3
I struggled with this too. It seemed at the time I was doing it that the force necessary to pop out the reflectors was going to end up causing some sort of damage to the bumper.
I wish I had a magic bullet method to give you that will make this easier but I don't. Rest assured that if you follow the directions found on this and other forums, you will succeed. Just be sure to be patient, take your time, tape up the screw driver (if you choose to use that method), and don't try to rush this as you will end up scratching or marring the paint on your bumper.
Let us know how it works out for you.
Good luck.
2008 AW E90 M3 - current
2002 TIAG E46 M3 - gone
1991 DiamondSchwartz E30 M3 - gone but not forgotten
      04-08-2009, 01:01 PM   #7
markymarc1979
2009 BMW E93  [0.00]
Good luck.
Forget this shit man. I'm starting to do damage to my bumper. What a crock of shit.
      04-08-2009, 01:20 PM   #8
montreal red
chris
montreal red's Avatar
Drives: White Boat
just be patient... its difficult to get the reflector out because they made it that way so it wont fall off so easily. just be patient and use a flat head and push the stock reflector up. get someone else to help you with another flat head to pry out the stock reflector once you have pushed it up. so you'll need 2 flat heads and a friend. then youre done!! not that difficult to do!
Current: 2013 F10 M5 & 2016 Mini JCW
2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone)
      04-08-2009, 01:23 PM   #9
markymarc1979
2009 BMW E93  [0.00]
Nevermind, I figured it out. The trick is to wedge the longer side of a credit card or a plastic card underneath the reflector. Once the card is wedged in there, then you have to wiggle and push the reflector upwards. After a few tries they poped right out.
Thank God
      04-08-2009, 07:29 PM   #10
Alex///M
Alex///M's Avatar
Thank God
Glad it worked out for you. Hopefully not too much damage was done that can't be polished or buffed out.
      04-08-2009, 08:02 PM   #11
sparkyg
sparkyg's Avatar
142
Drives: A6 Allroad
Good tip guys, thx
      04-08-2009, 09:11 PM   #12
revmmm
revmmm's Avatar
Drives: 2008 E93 M3 Cab SSII
2007 X5 4.8i  [0.00]
2008 M3 E93  [0.00]
I just switched my reflectors on Sunday and I had the same problem at first. I came back in and found this thread which really helped. I used the butt end of a screwdriver to "push" in the bumper right below the reflector (of course I used a micro-fibre cloth between them) because my thumb could not move the bumper enough when it was cold and then I was able to slide my finger in to lift the reflector out. I never would have figured it out on my own.
http://forums.roadfly.com/forums/bmw...8904911-4.html
2008 E93 M3 - SSII, 6MT, 19", EDC,...
      04-08-2009, 11:36 PM   #13
schnell325
Bored at work....
schnell325's Avatar
Thanks for the extra tips. I will try tomorrow.
      04-09-2009, 11:58 AM   #14
darklord
Ruler of the Universe
darklord's Avatar
Drives: 11 Silver Merc E63 (W212)
Where did you guys buy the coloured bumper inserts?
      04-09-2009, 11:59 AM   #15
darklord
darklord's Avatar
And good link and suggestions
m3post
