05-01-2009, 04:49 AM | #1 |
Rep 10
Looking to buy KW V3
Just took delivered my E92 M and looking to purchase coilover. Should I wait for the PSS10 to come to the state or should I go for the KW? How much for the KW?
For KW, I am worry that the spring rate and valueing will be too aggressive for crazy bumpy NJ/NY roads. |
05-02-2009, 08:02 AM | #4 |
Stay Ripping
60
Rep 547
I think the KW V3 will be perfect for your needs. They do not run stiff spring rates(progressive as well) and you can adjust the dampening and rebound. I am on the same crappy NY roads, except I am scared the V3 wont be stiff enough and am leaning towards the clubsports.
05-02-2009, 09:54 PM | #5 |
Rep 9,032
Shouldn't you be able to adjust how stiff they are with the springs and shock adjustments?
I though the Club Sports just had camber plates, and better springs?
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
05-04-2009, 10:53 PM | #6 |
Rep 10
Yes, there should be alot of adjustments. But I am still worry that the softest setting will be a lot more harsh than stock. I have tried bilstein for my E46 M, and the ride is comparable with stock (in term of comfort). That's why I prefer bilstein. However, it seems like I can't get them in the states yet, and the only other popular coilover is the KW. That's why I am considering and asking for opinion for KW now.
05-05-2009, 03:43 PM | #7 |
Supreme Allied Commander
3857
Rep 54,419
Drives: F80 M3
It all depends what you plan to do with your M3. If you mostly do street driving, the KW V3 or PSS10s may be okay. Tracking your car? You will need the KW Clubsport, TCKline D/A, AST or something more aggressive.
05-09-2009, 10:34 AM | #8 |
Rep 3,523
fwiw there are problems with some KW on E90'ers cars
see http://www.e90post.com/forums/showthread.php?t=243156 I'd wait and bit and see if there are some design changes, or at least investigate the issues |
05-09-2009, 10:00 PM | #9 | |
Rep 10
05-10-2009, 02:37 AM | #10 |
yodog
197
Rep 5,025
So do the KW Clubsports come with camber plates as well?
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
05-10-2009, 03:51 AM | #11 |
Rep 44
KW
The KW coilovers are probably going to be between 2.5 and 3k dollars. This is for the highest end coilover they offer, which I believe to be the best suspension that can be purchased on the market today. They have some ridiculous tests that they've done on their products that are quite impressive. As for knowing about the V3, I have V3's on my 97 740iL. I will tell you that if you don't want a harder ride over stock, then there's no point for you to even get coilovers. They will be harsher, however the V3s will offer you the greatest amount of adjustment. Back to the V3s on my car though; AMAZING. Best performance mod to date and I don't think the ride is bad at all, however is dramatically different than my stock suspension.
05-11-2009, 09:38 AM | #12 | |
Rep 10
05-11-2009, 10:38 AM | #14 |
3857
Rep 54,419
Drives: F80 M3
05-11-2009, 07:14 PM | #15 |
Stay Ripping
60
Rep 547
05-11-2009, 11:07 PM | #17 | |
3857
Rep 54,419
Drives: F80 M3
The problem exists in what we have seen in the V1, V2, and V3's for the 135/335 is progressive rate springs that are too soft. The existing KW spring design is impossible to achieve linear rates. Springs are rather large and heavy, reduce reaction time, add weight, and reduce stroke. Just the opposite can be done with light weight Swift springs or similar to reduce weight, speed up reaction time, and increase stroke. In addition, the twist and unwinding of the springs are not under control causing irregular spring rates and noise. The Clubsport on the other hand is much much better than the V3 in terms of springs used, but still left room for improvments. |
05-14-2009, 04:16 AM | #18 | |
That Dr. DICKER to You
Rep 141
i could not have said so better myself D1cker 1
05-14-2009, 05:16 AM | #19 |
yodog
197
Rep 5,025
I guess if I get KW's, Clubsport is the way to go.
05-14-2009, 08:04 AM | #20 |
Rep 141
Typically
As car enthusiasts go there has to be someone here who's had PSS9 on the previous e46 who can compare them to the AST Kit. D1cker 1
05-14-2009, 08:14 AM | #21 |
11817
Rep 23,187
so what im getting from hp autowerks is that there isnt really a good set out yet? im interested in a set but as a track mod so want stiffer spring rates. i do care though if they are overly bouncy since i will split time with street use. any ideal set up for both worlds?
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
05-14-2009, 07:58 PM | #22 |
Rep 1,125
