New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      07-06-2011, 03:36 PM   #1
integraworks
integraworks's Avatar
Drives: 2010 Z4 s35i
ESS Tune - Stage 2 Installed - WOW
Just installed ESS Tuning's ECU modification (Stage 2) and all I can say is WOW. This is a totally different car now. The take off speed, roll on speed and great exhaust notes are only surpassed by the sheer exhilaration of driving the car. Well done ESS!
http://www.esstuning.com/categories/...%252dDrive35i/
      07-07-2011, 04:07 PM   #2
uslic001
Drives: 2009 s35i Z4
Was it easy to install? How long did it take to install? Does it create error codes that will be picked up when you take the care in for service?
Bryan
      07-07-2011, 05:14 PM   #3
[DT]
Drives: (Shopping) Z4s
Bryan
It's my understanding that the ESS unit plugs into a harness (something like a diagnostics port) and flashes the factory ECU with a new program. Additionally, it (before the aftermarket tuning) can backup the factory programming.
So backup OEM, flash ESS ... have fun ... restore OEM, take to dealer.
I think I read someone posting that it took 15 minutes to flash the ESS tune.
I really like the idea of not physically touching or wiring up anything like a piggyback controller. No chances of breaking a harness or pin, or doing anything that shows the ECU has been accessed (like dinging up the cover/bolts/etc).
      07-07-2011, 05:48 PM   #4
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
It is a very easy process.
1.) Plug the handheld unit into the OBD II port.
2.) Copy the stock file.
3.) Email the stock file to ESS.
4.) load received ESS files onto the handheld unit via USB.
5.) Plug the handheld unit in and select the tune you wish to use.
6.) ENJOY.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      07-07-2011, 06:10 PM   #5
integraworks
Bryan
Yes it was very easy to install. ESS sends you a handheld interface unit and a cable that plugs into a socket located inside the car. You download a software update, then record the OEM ECU program onto the unit and backup onto your computer for future use. Send them the OEM file via email and a few hours later they send you the MOD ECU program. You load this onto the handheld unit and then upload it into the car. The upload took about 20 mins. The only odd thing was the fuel pump came on and stayed on during the upload of the MOD ECU program... that sort of concerned me but no harm was done.
No error codes have cropped up and all systems work just fine.
Before you take the car in for service you upload the original OEM ECU Program that you have stored on your computer.
I compared the JB4 to the ESS system and ultimately it was the simplicity of the ESS that won me over. No hardware to install, adapt or malfunction.
      07-07-2011, 09:19 PM   #6
cakePlease
Drives: 2011 Z4 35i
Wow, you mean with this you can ultimately get an extra 100HP for under $1k? That's amazing!
      07-07-2011, 10:18 PM   #7
[DT]
Ahh, they use the factory tune for a starting point - they take your program, patch it, and reload it. I suspect it must have a key that and/or some kind of cipher that authorizes the program, that's tested during startup, interesting stuff.
The ease of install/uninstall is very compelling, even with the cheaper JB pricing and the extra features.
Yeah, factory FI is always slick for adding some HP. Tune, a little exhaust work, so many FI cars can pick up 75-100+ HP. It's one of the things that makes the N5x powered BMWs so interesting!
      07-07-2011, 10:33 PM   #8
integraworks
Yes, and there is NO doubt in my mind that the 100Hp more is there after driving the car with the Stage 2 Program installed. It is remarkable.
So fun zipping along at 60Kph in 3rd and then poking the gas a bit and in only a couple of seconds doing 120 Kph... and the sounds!
      07-07-2011, 11:14 PM   #9
jdogg2000
jdogg2000's Avatar
26
Drives: 2011 Carrera GTS
Quick question along these lines... does anyone know how often the dealer updates the software on these cars? I'm under the impression that if they install an ECU update to your car, you'd have to resend the car's ECU program to ESS and they charge $100 for an updated map for your car.
//'04 330i ZHP (gone) //'07 E92 335i (gone)//'08 SG E93 M3 (gone)
//'11 Z4 sDrive35i (gone)//'11 Jet Black E92 M3 (gone)
//'11 Carrera GTS
      07-08-2011, 08:50 AM   #10
sales@ESSTuning
sales@ESSTuning's Avatar
391
Drives: ESS M3 / M4
If the factory software is updated by the dealer you can simply read and re-send for an update if you have the Direct Flash. The Direct Flash can hold up to 10 maps and allows you to remove / replace files as often as needed.
I have been driving our new project Z4 35is with this software. It is a fantastic performing tune that provides better than factory drivability and a large increase in power.
      07-08-2011, 11:02 AM   #11
sDrive35i
Drives: 2011 Z4 sDrive35i
How does it increase the sound? If you have DCT, does it make the shifting sounds louder?
2011 BMW Z4 sDrive35i
2010 Nissan Maxima
      07-08-2011, 11:59 AM   #12
Wraith.
Wraith.'s Avatar
71
Drives: ED '11 Z4 35is
So Roman, with the 35iS and stage 2 are we talking 430Hp?
      07-08-2011, 12:12 PM   #13
suvidh
suvidh's Avatar
India
18
Drives: 2010 Z4 35i , 2011 f10 525d
Yes the shifts are much louder n sweet
      07-08-2011, 12:17 PM   #14
suvidh
suvidh's Avatar
India
18
Was anyone able to measure 0-100 time and 1/4 mile time with and without the tune ?
      07-08-2011, 07:16 PM   #15
Dr Stig 2
Criminally Insane
Dr Stig 2's Avatar
Australia
53
Drives: Like a Demon!
2010 BMW Z4 35is  [10.00]
2013 BMW X5 30d  [0.00]
Dont mind me, just watching for more details...
Dr Stig
2010 Z4 35is
2011 X3 30d M Sport
Australia
      07-08-2011, 08:25 PM   #16
sales@ESSTuning
391
Drives: ESS M3 / M4
On pump 91 / 93 octane im going to say its around 400-410 HP with the tune alone. We are working on Downpipes, Intercooler and turbo upgrades currently. We will see how much power we can get out of her
      07-08-2011, 10:55 PM   #17
disruptv
Drives: 3M
09 3m  [0.00]
roman,
on a z435is, what can I make at the wheels on a stg2 2 with no other mods other than a ess flash? what type of whp gain can I expect?
      07-09-2011, 09:36 AM   #18
Auraraptor
Drives: Exx
You can hold ten maps:
1. Stock
2. Stage 1 tune
3. Stage 2 tune
3. ???
4. ???
5. ???
10. Profit?
      07-09-2011, 10:27 AM   #19
ridin135
Drives: Depends on the day
How much psi does the stage 2 run
      07-09-2011, 09:42 PM   #20
Alext
Drives: B M W
Hey roman are you saying that @ approx 400-410HP the 35is makes more HP than a normal N54 car on Stage 2???
      07-09-2011, 09:51 PM   #21
Alext
Drives: B M W
Also have you managed to raise the RPM limit on DCT equipped cars yet?
(The ESS website suggests RPM limit of 7200RPM).
DirectFlash Stage 2 :
Top Speed Governor: Removed
RPM Limit: 7200RPM
Fuel requirement: 93US/98Euro
Horsepower: 400 DIN (Stock 306) - 390DIN if used with stock intercooler
Torque: 550NM (Stock 400NM)
http://www.esstuning.com/products/ES...-Software.html
      07-10-2011, 02:49 AM   #22
sales@ESSTuning
391
Drives: ESS M3 / M4
14 psi
We usually see N54 stage 2 dyno's in the 350 whp range. This is about what a 400-410 hp car will make taking the average 15% drivetrain loss into consideration. The 35is is just a slightly tuned version of the 35i. When tuned with our stage 1 or stage 2 software the power on these two specs is about the same.
zpost
