08-04-2011, 10:59 PM | #1 |
Rep 1,797
Anyone ever swap interior trim?
I have brushed aluminum and considering move to oem cf. Expensive? Is it a DIY job??
Previous Rides: 535xi, M235xi, X3, E92 M3, E70 X5 35d, X6 50i, X6 35i, E60 550i, E46 M3 Cabriolet, E39 540i, E36 328i
08-04-2011, 11:07 PM | #2 |
Rep 4,144
It's a DIY. I've taken the trim on and off. Is it expensive for the OEM CF? I'd say so. But check the price with Tischer (getbmwparts dot com).
Cheers.
2017 F80 YMB.
08-04-2011, 11:17 PM | #3 |
smiling amid the chaos...
27
Rep 409
I ended up swapping out mine for the iND OEM painted trim in Space Grey, but Nate gave me a great price on the OEM CF trim as my second choice when I was shopping.
Don't overlook the the painted OEM option from iND - I love mine complete with steering wheel insert it looks great and the quality is top notch. |
08-04-2011, 11:26 PM | #5 | |
Rep 4,144
Cheers.
2017 F80 YMB.
08-05-2011, 03:22 AM | #6 |
Rep 275
I had the leather in cf weave and I switched to the oem CF interior trim , cost was 3000$ ( in India) , don't know about DIY as the dealership installed it for me. Took em a few hours .
08-05-2011, 07:47 AM | #7 |
Field Marshall
307
Rep 515
Swap Interior Trim
As it happens, I am exchanging mine today. Purchase trim tools from here: http://www.griotsgarage.com/product/...with+hammer.do
There are threads on here describing how it's done, having done it before, I would say it's fairly simple if you do it slowly, don't attempt if you are pressed for time. I purchased the OEM cf from Tischer for $1 175 - getbmwparts.com This is a very good price for oem. PS: I am swapping out the aluminum trim. |
08-05-2011, 08:52 AM | #9 |
Rep 13,020
08-05-2011, 10:45 AM | #10 |
Rep 725
I was just thinking about doing this the other day, so glad this thread popped up. I have aluminum trim and love the look but it is creaking like hell. It's really strange because its mostly when the AC is on. Really cheap and frustrating. I was hoping if I moved to CF it wouldn't make all the noise. But who knows. Any thoughts? Also has anyone ever had an rattling problems upon removing and replacing trim?
2016 340i M-Sport 6-MT(on order)
2013 335is (still have) 2011.5 M3 ZCP (traded in) |
08-05-2011, 11:12 AM | #13 | |
Rep 1,395
Club 6MT 2008 E92 M3 6MT, AW/Blk Ext., brushed aluminum 2006 E46 M3 ZCP 6MT Carbon blk/blk(sold) 2001 E46 325Xi 5MT Jet Blk/Blk (sold) |
08-05-2011, 11:24 AM | #14 | |
Rep 13,020
http://www.m3post.com/forums/showpos...70&postcount=1 |
08-05-2011, 11:27 AM | #15 |
Rep 725
Yes, please do because no one else seems to be having this problem. Of course there are other spots in the car and I take it into the dealership and 1-they can never hear it...of course and 2 they said that if they messed with any of the factory clips in there that it would mess things up worse which is understandable. It just seems like my trim is defective or something because I cannot imagine that BMW would put this materiel in a car that would make absurd noises like this, especially when I have the AC turned on. I don't know how bad I have to let it get before the dealership will do anything.
08-05-2011, 11:31 AM | #16 |
Rep 725
Also-does anyone have a part number for the OEM CF trim from Tischer?
08-05-2011, 01:04 PM | #18 |
Rep 6,125
I had Carbon leather trim and replaced with OEM C/F trims.
IT's DIY project and here are a few thoughts from the DIY project. 1. All 4 doors trims(I have a sedan) and driver side center trim (on top of light unit) were very easy with trim removal tools (I have one from EAS). 2. center dash trim was a bit tricky due to short wire connector behind emergency blinker unit. It requires some time, effort but tweezer would help a lot. 3. Carbon leather trims have strong metal trims with carbon leather overlay so it was almost indestructible (leather can be damage but will not break any pin or trim from pulling) so as long as you're careful enough, it's easy. I'm sure your aluminum trim will be the same. 4. On the other hand, Carbon Fiber trims are plastic with carbon fiber overlay (their C/F mirror caps, splitters and spoiler have real 100% carbon fiber but C/F trims are overlay). So it's not strong as carbon leather trim pieces. So installing was easy but I'm slightly afraid if I need to take them out as it's plastic construction with metal pins. 5. Even though C/F trims price is a bit high side, it worked out ok for me as used set of Carbon leather trims have pretty good demands in the forum. 6. For people who wants to know more: I sold my E90 Carbon Leather trim set for 650 (I'm sure you can get a bit more for E92/3 kits as they're more expensive than E90s). So upgrading cost is going to be about 500-600 dollars depends on the deal you get from selling your trims. In my case, I bought used C/F trims for about 750 and sold my Carbon Leather trims for 650 so I only spent 100 to upgrade. =) I'm not sure how much demands you will get with Aluminum trims but I'm sure you can get decent money (compare to ti shadow or wood trims). So you may wanna post feeler first then decide your upgrade. If you sell yours, C/F trims are good upgrade (based on about 500 dollars spending) but it's really not worth if you have to spend 1100-1300 for C/F trims.
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 |
08-05-2011, 10:24 PM | #19 | |
Rep 1,797
08-05-2011, 11:58 PM | #20 |
Female driving enthusiast :P
76
Rep 2,308
Drives: Bimmer
Can you get piano black trim from Tischer? OP, I think that would look awesome with your jerez exterior and bamboo interior.
2013 M3 coupe (Azurite Black, Black, Piano Black)
+ miata nut (2 miatas) + Mk6 GTI 5-door hatch (our mini-SUV ) |
08-06-2011, 09:49 AM | #21 |
Rep 1,797
You're right...It would sure work with my colors...I'm not a fan enough of it to go through the time and expense of swapping from aluminum though.
08-06-2011, 01:32 PM | #22 |
Rep 6,845
Drives: 2018 Audi RS5 coupe
You can also get trim painted in your body colour from IND for about $650
I wanna get it for my 2012 when it comes Painted le mans blue to match car And I want to get the new performance steering wheel with the blue line at the top to match Should look good
