M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding
      10-30-2013, 08:03 AM   #1
dhirm5
Drives: 2014 M5 ZCP, 2014 X5 35d
Coding cheatsheet
Heres a much more readable cheatsheet than the other that's floating around and contains info for pre and post LCI:
File Type: pdf By Function Cheat Sheet F10 2011-LCI (MWPos) 10-24-2013.pdf (213.2 KB, 74105 views)
2017 Porsche 911GTS - Agate Gray on Black
2009 Aston Martin DBS - Casino Royale Gray on Black (sold)
2014 M5 ZCP - Azurite Black over SSII Full (gone)
2009 M5 - Carbon Black over Sepang Full (gone - not forgotten)
2001 740i M-Sport - Carbon Black over Black (gone - not forgotten)
      10-30-2013, 09:00 AM   #2
skypx
Veteran U.S. Army
skypx's Avatar
Germany
62
Drives: ///M
Cool, now all I need is the "coding for dummies" guide to get this done.
      11-10-2013, 03:23 PM   #3
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
Ask, and ye shall receive
The How-To guide is based upon E-Sys 3.1X.X and the current version is 3.2X but the screens are similar enough that my version-dated How-To guide is still good enough.
File Type: pdf E-SyS 3.18.4 step-by-step (MWPos) V 5-19-2013.pdf (1.62 MB, 16192 views)
File Type: pdf FA (VO) Step-By-Step (MWPos) 8-24-2013.pdf (1.05 MB, 11834 views)
Regards,
MWPos
      11-10-2013, 03:28 PM   #4
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
I've also created this very clunky spreadsheet so that I can chose functions to code, then re-sort the spreadsheet by ECU. Coding by ECU, instead of By Function, is much more efficient. This is targeted at the non-M F10, so some functions are not relevant to the M5. The "Technology" column is just a way to discriminate between older and newer F10s. The newer have the HU-NBT. The older, like mine, have the HU_CIC.
In order to view the attachment correctly, delete ".pdf" from the end.
Regards,
MWPos
      12-22-2013, 02:54 PM   #5
stealth.pilot
Knight Commander
stealth.pilot's Avatar
Drives: 2014 911 Turbo S
Great spreadsheet.
I have one add for you:
To turn off amber side-marker safety lights:
FRM>3060>FRM_EFFEKTIV, 20 / U_EFF_SM_V, to turn off set to Wert_01, Werte=00
FYI this doesn't work on 2014 with LEDs. It does work on 2013 with Xenon.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray
      12-25-2013, 12:29 PM   #6
Spasta
Drives: E39
nice posts. Thanks
      07-19-2016, 02:24 PM   #7
Fast400
Fast400's Avatar
Germany
689
Drives: iX M60
2014 BMW  [0.00]
Has anyone coded taillights on with daytime running lights?
I can't find it anywhere
      07-28-2016, 12:02 AM   #8
Almaretto
Almaretto's Avatar
2376
Drives: Test Vehicles
Did you check FRM DRL_MODUS?
      11-15-2016, 12:42 AM   #9
tec333
Drives: 2013 M5
can someone point me in the right direction to download and install/set up e-sys
      11-15-2016, 12:49 AM   #10
Almaretto
Almaretto's Avatar
2376
PM sent
tec33389.00
      11-16-2016, 01:18 PM   #11
makscheban
Drives: 2014 BMW 535i
Hi guys,
Can anyone tell me how to program a new headlight driver module on a 2014 bmw 5 series using esys?
I replaced both headlights due to front end damage, used the original modules on the right side and everything works fine. However, on the left side, I had to buy a brand new driver module. I am able to connect to esys and code some things, but not able figure out how to program the vin on to the new driver module.
Thanks!
      11-16-2016, 01:29 PM   #12
Almaretto
Almaretto's Avatar
2376
Originally Posted by makscheban View Post
Hi guys,
Thanks!
Flashing Guide and in case you need to initialize.
      11-16-2016, 02:38 PM   #13
makscheban
So flashing it will fix the issue? Which ecu do I flash?
Thanks!
      11-16-2016, 02:56 PM   #14
Almaretto
Almaretto's Avatar
2376
Thanks!
Lighting modules for an F10 include FRM, LHM x2, and TMS x2. Did you replace any of those?
      11-16-2016, 06:39 PM   #15
makscheban
I replaced the TMS module and the LED/angel eye module(I believe its the LHM module?)
      11-16-2016, 07:09 PM   #16
Almaretto
Almaretto's Avatar
2376
FRM (Footwell Module) control some lighting functions, but you would have errors on both sides.
LHML = Left LED Main headlight module.
LHMR = Right LED Main Headlight Module.
You can use E-sys or ISTA-P. ISTA+ requires ICOM.
File Type: pdf Replacing Control Unit for Xenon Headlight.pdf (254.1 KB, 3297 views)
      11-16-2016, 07:33 PM   #17
makscheban
Thank You, very much. I will try it tomorrow.
      11-16-2016, 07:36 PM   #18
Almaretto
Almaretto's Avatar
2376
      11-16-2016, 08:01 PM   #19
makscheban
Just to confirm, I need to flash the above ecus?
      11-16-2016, 08:22 PM   #20
Almaretto
Almaretto's Avatar
2376
You are going to need to check the firmware versions of ECU's and Dependencies. Both are discussed in E-sys guide.
      11-16-2016, 08:58 PM   #21
makscheban
Do you have the guide by any chance?
      11-16-2016, 09:18 PM   #22
Almaretto
Almaretto's Avatar
2376
Linked in Post #12
m5post
