02-20-2014, 07:09 PM | #1 |
Rep 3
CCB or aftermarket Brembo brakes?
I was considering the bmw CCB, since I really want big 6/4 piston brake on the new m4, and I will maybe do several track days per year. Is it worth the 8000+ bucks, or just get some after market brakes with the steel rotor? Any advice for the quantity and pricing for these brakes?
02-20-2014, 07:10 PM | #2 | |
Rep 2,633
02-20-2014, 07:13 PM | #3 | |
Rep 9,034
You can get StopTech ST60/St40 for around $5,000, or even less. Brembo's are usually around $1,500 more.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
02-20-2014, 07:17 PM | #5 |
Rep 348
CCB is absolutely the way to go. Capitalize the cost of the brakes in the price of the car. Get something that's been tested and will work perfectly. BBK is hard to get perfect the first time.
I think the option will only end up costing USD $6900 or less.
WTB: 2016 M3 sedan, Black Sapphire, Extended Sakhir Lether, Ceramic Brakes, 19" black wheels, Lighting Package, HK sound, USB/Bluetooth
Sold: 2006 e90 325i 6MT, ground control coilovers, Remus exhaust |
02-20-2014, 07:19 PM | #6 |
Rep 3
Actually I will get the steel rotors when the CCB rotors run off. So I guess it's worth to get the CCB.
02-20-2014, 07:23 PM | #8 | |
Rep 9,034
OP said he's going to track it, which will signficantly shorten the life of the rotor. You'll also be limited on what pads you can use. Porsche guys who used other track pads ruined their CCB rotors much faster than the ones who used the Porsche track pads. .
02-20-2014, 07:27 PM | #9 | |
Rep 2,633
02-20-2014, 07:30 PM | #10 | |
Rep 348
There's two kinds of tracking. There's the weekend warrior, non competitive stuff you do with BMW CCA in HPDE events. This is perfect for CCB. Then there's competition cars like the GT3 Cup and the M235i club race. These cars do not have VIN numbers and are not street cars. While having CCB on racecars is great, those cars are $200,000, the engine mileage is measured in hours like a boat, and they require about $50k in spare parts to keep running properly. In these cases unless you have another $50k laying around you skip the CCB. The Pagid RSC1 will be one level more abrasive than the BMW factory pad. This is the pad you want to run. The stock pads should last about 4 weekends. These are endurance pads and will last 8 weekends or more.
Sold: 2006 e90 325i 6MT, ground control coilovers, Remus exhaust Last edited by gee-m-w; 02-20-2014 at 07:35 PM.. |
02-20-2014, 07:34 PM | #11 |
Rep 348
They were like $7500 Canadian. Each US option price is about 10-15% lower.
bluecusion57.00 |
02-20-2014, 07:37 PM | #13 |
Law Enforcer
25162
Rep 22,293
Drives: '22 Chalk Gray Porsche C2S
02-20-2014, 07:51 PM | #14 |
Rep 348
Sorry for the poor communication on my part. Invoice price on that option should land right around $6930. The options are 15% discount to MSRP, which is $6927.
I add things up as invoice and then add a "dealer profit" at the end before tax. Probably $3000.
02-20-2014, 08:19 PM | #15 |
Rep 1,022
brembos are over priced. just get front 6pot ap racing bbk. dont really need 4pot rear. majority of stopping force during hard braking comes from front end anyway. 3500 well spent. good to go
02-20-2014, 08:40 PM | #16 | |
Rep 348
If you can order this from the factory, get better braking, less weight, etc. it's a no brainer to spend the $7k. It could theoretically even increase resale.
02-20-2014, 08:45 PM | #17 | ||
Rep 2,633
02-20-2014, 09:03 PM | #18 | |
Rep 20,741
Drives: 2021 911 turbo
IMO, the base iron brakes with good race pads (and maybe better fluid) is the better option. As others have stated, there is another thread with plenty of good discussions on the topic. If you plan to track significantly like I do, there simply is no business case for the CCBs. Feedback form other makes is that CCBs don't last much longer than iron rotors when used at the track. Except for PF08 pads, I run a completely stock brake setup (even the fluid) on my E92 and never encountered brake fade. I track my car at the rate of 18-20 track days per season and my E92 has 5½ seasons under it's belt. I have changed 2 sets of front rotors and my rears are due this spring for a total cost of $2500 in rotors. The CCBs are a $8500 option in Canada, so even if they last the full 6 years (which they most likely won't), they are still significantly more expensive. Further, when going with CCBs, you are stuck with having to run 19" tires. There are far less choice in 19" r-comps and they are significantly more expensive than 18". So you also need to factor in the increased cost of tires. Now if you go with the CCB option and switch to iron rotors, consider the lost performance of the significant weight addition (increased unsprung and rotational mass). The CCB callipers are much heavier than the base callipers and the replacement iron rotors will be significantly heavier than the base OEM iron rotors due to their increased diameter. The CCB might offer a slight performance advantage. But for me, it is not worth the extra cost. Last edited by CanAutM3; 02-21-2014 at 05:48 AM.. |
02-20-2014, 09:09 PM | #19 |
Rep 348
You have two options for 19" DOT legal R compound tires. The inexpensive choice is Toyo R888 at about $300 a tire. The expensive choice is Dunlop Sport Maxx Race at around $600 a tire, which is the OEM equipment on the new GT3.
You're best off passing on the Pirelli P Zero Corsa System and the Pilot Sport Cup (which is shaved to something absurd like 5/32). These two tires cost you more per mile to run than gasoline by a significant margin. It's like $1 per mile driven. $3000 and it lasts 3000 miles. Most people (me included) do just fine on Pilot Super Sports, which should be the OEM equipment. The downside of putting race pads on an M3 with drilled rotors is they will make a ton of embarrassing noise on the street, whether you go with Performance Friction or Pagid. Swapping pads is a huge pain the ass and is a big compromise with pad bedding (you never really get a good bond between the rotor and the pad if you always switch them). With the CCB it's one pad for everything.
02-20-2014, 09:11 PM | #20 |
Rep 20,741
02-20-2014, 09:15 PM | #21 |
Rep 348
I'm telling you, once you go 380mm BBK you never go back. 19" is the new 18". The tire manufacturers will start making more 19" R comp sizes for the Porsche, BMW, Audi and other models.
02-20-2014, 09:19 PM | #22 |
Rep 20,741
